Csharp/MapScript
Sean Gillies
sgillies at FRII.COM
Thu Nov 17 16:28:29 EST 2005
I wrote the following doc a few months ago, and am pretty sure that
most of it still applies
http://ms.gis.umn.edu/docs/faq/thread_safety
cheers,
Sean
On Nov 17, 2005, at 1:18 PM, Ian Erickson wrote:
> I'd like to know the answer to this as well...are there things that we
> can do that would promote thread safety - like building MapServer
> without GDAL support?
> - Ian
> Abe Gillespie wrote:
>> Tamas,
>> Isn't there still tremendous threading issues that cause endless
>> problems when hosted in ASP.NET? Or has that been solved ... or have
>> people found work-arounds?
>> Thanks.
>> -Abe
>> On 11/17/05, Tamas Szekeres <szekeres.tamas at freemail.hu> wrote:
>>> I recommend to compile mapserver and the related libraries for
>>> yourself
>>> before using them with ASP.NET. It is highly suggested to use the
>>> same
>>> compiler version for theese packages (eg VS 2003).
>>> The Win32 compilation instructions can be found at:
>>> http://mapserver.gis.umn.edu/doc46/win32_compile-howto.html
>>> to compile use Visual Studio .NET Command Prompt and nmake.
>>> To compile mapscript:
>>> 1. download the latest SWIGWin package which contains the Win32
>>> binary
>>> SWIG.EXE
>>> 2. edit nmake.opt for referring to the SWIG location
>>> 3. In Visual Studio .NET Command Prompt cd to mapscript/csharp
>>> 4. nmake -f makefile.vc
>>> To test the compilation
>>> 5. Create an empty ASP.NET C# project
>>> 6. Add reference to the previously compiled mapscript_csharp.dll
>>> 6. Use the following code to test the map creation
>>> private void Page_Load(object sender, System.EventArgs e)
>>> // Put user code to initialize the page here
>>> using (mapObj map = new mapObj(@"C:\Maps\MapFiles
>>> \mymap.map"))
>>> using(imageObj image = map.draw())
>>> byte[] img = image.getBytes();
>>> Response.BinaryWrite(img);
>>> 7. Before testing the project make sure that all of the dlls
>>> (depending on
>>> the mapserver compiler options, eg: bgd.dll, gdal13.dll,
>>> libcurl.dll,
>>> libmap.dll, mapscript.dll, mapscript_csharp.dll, proj.dll) reside
>>> in the
>>> correct location. I recommend to place the dll-s to the same
>>> directory as
>>> your target file.
>>> Best Regards,
>>> Tamas Szekeres
>>> On Tue, 15 Nov 2005 13:08:06 -0600, Suman G. Pradhan
>>> <sgp_dgtek at HOTMAIL.COM> wrote:
>>>> Dear all
>>>> Please some one help me finding Csharp/MapScript.
>>>> Why there is no resources related with MapServer and .Net ?
Sean Gillies
sgillies at frii dot com
http://zcologia.com/news
