[mapserver] Java VM Crashes using the Mapscript API
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Mon Nov 21 02:45:58 EST 2005
For load and stress testing of my web apps (but it can be used for web
services and databases too) I use jmeter
http://jakarta.apache.org/jmeter
It is an excellent tool that will also allow to do distributed testing
as the request can be dispatched to n clients controlled by a single
one. It also has support for cookie-based sessions which is not
available in other products.
Best regards,
Umberto
On 11/18/05, umn-ms at hydrotec.de <umn-ms at hydrotec.de> wrote:
> Hallo Umberto
> Where to start?
> > In my applications I *never* create mapscript objects except for the
> > main mapObj (I do not add layers, classes or anything else in Java
> > code). This should explain why I do not see a reason for calling
> > delete explicitly.
> The delete-issue is indeed only necessary if one creates Java-Wrappers
> on sub-objects.
> The example in
> http://article.gmane.org/gmane.comp.gis.mapserver.user/11678
> also bases on creating sub-objects.
> > I would suggest that this affirmation be checked against code because
> > I am not sure that the swig glue code will always be safe with regard
> > to double frees. In general I do not see any possible benefit coming
> > from this behaviour, but I could be wrong.
> On the "double free"-aspect: The delete's code code looks like this:
> public void delete() {
> if(swigCPtr != 0 && swigCMemOwn) {
> swigCMemOwn = false;
> mapscriptJNI.delete_mapObj(swigCPtr);
> swigCPtr = 0;
> So calling "delete" many times is harmless.
> > In fact I disagree when you say that this requires 'only small
> > changes', this is a major effort:
> > - keep in mind that the core swig code is also used by other languages
> > and to my knowledge in python there is no need to do garbage
> > collection yourself, so we should write swig glue code especially for
> > Java.
> I have to confess, that "Swig" is a point I've overseen.
> "only small changes" didn't take the swig-process into account,
> but only the java-code swig creates. (And no doubt a swig-way
> is hardly needed.) Mmmh...
> Would be intersting to see how other Java/Swig-Apps manage this.
> > - finally there is the enormous problem of global variables in
> > mapserver sources which make some of it not thread safe.
> Using java-"synchronized" frequently is unfortunaltey indispensable
> for now.
> > BTW: how do you stress test your application (software, configuration,
> etc)?
> We wrote a Java Programm which creates n threads, for simulating n browsers.
> Each thread sleeps for 2 or 3 seconds and then issues a http-Request
> to the server to force the server to create a map.
> This is cycled for m-times creating m maps.
> The requests vary the map-extends which are produced.
> Example: n=4 Browsers; Each making m=5000 requests.
> (runs quite long ...)
> I do remember, that some time ago you suggested a special software
> for this task, but we found it easier to write a Java-Programm on our own.
> > > - On our testsystem it runs very fine for weeks.
> > > - On the customers (production-)machine we still have Tomcat crashes
> about
> > ... Java mapscript can be used ... with reasonable stability
> > and performance when only the following components are involved:
> > - raster support (via gdal)
> Mmh. Could be, that our customers production-machine uses rasters and
> the testsystem only Shape and Oracle.
> I will have a closer look, wether this makes the difference.
> Have a nice weekend
> Benedikt
