Line Labels (multiple Labels)
Blammo
bob.basques at CI.STPAUL.MN.US
Mon Nov 21 21:57:00 EST 2005
All,
OK, I thought about this some more . . . .
Just as a cheat to get something going, what about just stringing two of
the labels together, top and bottom of the line, and seperate them by
some spaces in the text. This would essentailly give me what I'm
looking for, but it also has one problem, I need to be able to figure
out the line direction. The address ranges are from-to related to the
beginning/end of the lines. Is there a way to tell which direction a
line is drawn? I believe the AUTO align does something like this
doesn't it?
The output would look something like:
LeftMin LeftMax
RightMin RightMax
RightMax RightMin
LeftMax LeftMin
bobb
Stephen Woodbridge wrote:
> I have asked about this feature in the past. It would be a very nice
> feature to have, but it is not available in mapserver yet unless you
> want to code it up maporama does it and it looks very nice.
> http://www.maporama.com/share/
> I think it would be great if mapserver supported a more abstract label
> positioning grammar like:
> LABEL
> LABELITEM <field>
> LOCATION
> POSITION ...
> PERCENT_ALONG <float>
> SIDE [LEFT|RIGHT|CENTER|INSIDE|OUTSIDE]
> OFFSET [X|Y|NORMAL] <float>
> END
> END
> Then you could attach multiple label blocks to a layer to generate the
> labels you want. Moving LABELITEM into the LABEL block allows each
> block too have its on item field.
> This could also be used to display labels along polygon boundaries
> using INSIDE|OUTSIDE for things like administrative boundaries.
> -Steve
> Bob Basques wrote:
>> All,
>> I think I saw something like this being asked a few months back, but
>> haven't found it in a search.
>> I need to be able to label a line at both ends and on both sides.
>> Are there some techniques to use in MapServer for this? I can
>> generate the point locations from other software for the labels, but
>> the dataset changes quite frequently and I woulds like to pursue an
>> automated method if possible.
>> What I'm trying to label is a Street Centerline with the address
>> ranges on both ends, we also have a right/left distinction at both
>> ends so that I would need a label on each side of the line as well.
>> Needless to say the labels would need to align with the line segment
>> as well rotationally
>> Even a search keyword would help if someone knows of something in the
>> archives.
>> Thanks for any info.
>> bobb
Skipped content of type multipart/related
