php5.0.5
Janeks Kamerovskis
janeks.kamerovskis at SILVA.LV
Wed Nov 23 10:08:06 EST 2005
Some couple days ago I also updated MapServer and PHP MapScript.
Probably I faced with the same problem.
But it seems that it was so that PHP installation/configuration are
different from previous versions.
I also could not load php_mapscrit_46.dll.
The problem disapears when I put all PHP's dlls into his (where php.exe)
directory. That was writen somewhere in PHP's readme file.
In this case Win2000 and IIS.
Hope it helps,
Janeks
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Yewondwossen Assefa
> Sent: Wednesday, November 23, 2005 4:39 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] php5.0.5
> Artur,
> I think I missed the posts about dlls missing and could not locate it.
> Could you please repost it. Could you please also run dlldepend on it,
> It might give you whicgh dlls are mising.
> Later,
> Artur Skalski wrote:
> > Hi All
> > I know that this subject was discussed some time ago, but I'm still
> facing
> > this problem with loading php_mapscrit_46.dll for php 5.0.5. I have IIS
> and
> > php cgi running very well, I've downloaded the php_mapscript_46.dll
> build
> > for php 5.0.5 and still can't load this library. I've read the posts
> obut it
> > that there ara some others dll missing that should also be supported,
> can
> > anyone tell, what are these dll's, how to get them, how to solve this
> > problem?
> > regards
> > Artur
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
