php5.0.5
Janeks Kamerovskis janeks.kamerovskis at SILVA.LV
Wed Nov 23 10:30:35 EST 2005
I installed MapScript more for testing purposes. So I have only few very
simple and ugly php test scripts, but all of them worked like before.
Janeks
> -----Original Message-----
> From: Skalski Artur - askals [mailto:Artur.Skalski at acxiom.com]
> Sent: Wednesday, November 23, 2005 5:16 PM
> To: Janeks Kamerovskis
> Subject: RE: [UMN_MAPSERVER-USERS] php5.0.5
> Yes, that's true, I've came up with the same idea, and now all works fine
> (loading the module), but this was one of three ways of installing
> phpmapscirpt was, the first was to update system PATH, and this doesn't
> work.
> But did you faced any problems with work of your application after going
> on php 5.0.5, because I cant get it work, I keep getting lots of error
> messages.. :(
> Artur
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
> Behalf Of Janeks Kamerovskis
> Sent: Wednesday, November 23, 2005 4:08 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] php5.0.5
> Some couple days ago I also updated MapServer and PHP MapScript.
> Probably I faced with the same problem.
> But it seems that it was so that PHP installation/configuration are
> different from previous versions.
> I also could not load php_mapscrit_46.dll.
> The problem disapears when I put all PHP's dlls into his (where php.exe)
> directory. That was writen somewhere in PHP's readme file.
> In this case Win2000 and IIS.
> Hope it helps,
> Janeks
> > From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> > Behalf Of Yewondwossen Assefa
> > Sent: Wednesday, November 23, 2005 4:39 PM
> > Artur,
> >   I think I missed the posts about dlls missing and could not locate it.
> > Could you please repost it.  Could you please also run dlldepend on it,
> > It might give you whicgh dlls are mising.
> > Later,
> > Artur Skalski wrote:
> > > Hi All
> > > I know that this subject was discussed some time ago, but I'm still
> > facing
> > > this problem with loading php_mapscrit_46.dll for php 5.0.5. I have
> IIS
> > and
> > > php cgi running very well, I've downloaded the php_mapscript_46.dll
> > build
> > > for php 5.0.5 and still can't load this library. I've read the posts
> > obut it
> > > that there ara some others dll missing that should also be supported,
> > can
> > > anyone tell, what are these dll's, how to get them, how to solve this
> > > problem?
> > > regards
> > > Artur
> > Assefa Yewondwossen
> > Software Analyst
> > Email: assefa at dmsolutions.ca
> > http://www.dmsolutions.ca/
> > Phone: (613) 565-5056 (ext 14)
> > Fax:   (613) 565-0925
> The information contained in this communication is confidential, is
> intended only for the use of the recipient named above, and may be
> legally privileged.
> If the reader of this message is not the intended recipient, you are
> hereby notified that any dissemination, distribution or copying of this
> communication is strictly prohibited.
> If you have received this communication in error, please resend this
> communication to the sender and delete the original message or any copy
> of it from your computer system.
> Thank you.
