Bad colors with mapserver
Trond Michelsen
trondmm-mapserver at CRUSADERS.NO
Thu Nov 24 16:17:36 EST 2005
On Thu, Nov 24, 2005 at 12:37:14PM -0700, Sean Gillies wrote:
> On Nov 24, 2005, at 11:36 AM, Trond Michelsen wrote:
>> On Thu, Nov 24, 2005 at 09:08:54AM -0800, Tyler Mitchell wrote:
>>>> name klimawms
>>>> imagetype png
>>> Hi Trond,
>>> Trying changing imagetype to PNG24...
>> Hmm. I've tried setting imagetype to "png24" without success. But I
>> can try "PNG24" as well. It'll have to wait until tomorrow, though.
> Sounds like you've used up all 256 colors in the standard 8-bit PNG
> palette. If JPEG looks OK, then 24-bit PNG should be OK too.
> One of the most common causes is anti-aliased freetype fonts. Your
> font color may be black, so you figure one color, right? Well, if you
> look at your image closely, you'll see that black text rendered with
> anti aliasing over a blue polygon actually uses 12+ colors. In the
> same map, you'll also have text over green polygons, red polygons,
> with another 12+ colors for each. It adds up quick. Using pixmap
> symbols can also eat up big chunks of color space in your output image.
Doh!
I can't believe I forgot about anti-aliasing. The text and logoes
aren't even supposed to be there. I was thinking of just creating a
shape-file which covers all tekst and logoes, but I suppose it's
better to ask for a set of pictures with nothing but the map.
I'll have a look at that tomorrow. Thanks.
> If you have to use an 8-bit indexed color PNG, you can reserve
> important colors by drawing layers with that color early. All you
> have to do is draw a single point or line.
Nice to know. Thanks.
Trond Michelsen
