problems querying ogr data source
Frank Warmerdam
warmerdam at POBOX.COM
Fri Nov 25 10:07:52 EST 2005
On 11/25/05, joanne cook <j.cook at oxfordarch.co.uk> wrote:
> Hi Frank,
> I don't think I can upgrade to the nightly snapshot of gdal/ogr as I don't have any compilation tools. Is there a work around for this, ie if I add a column called FID to my database table will that work?
Joanne,
No, that won't help. Are you using an VRT (OVF) file? If so, specifing
the FID in there may help as someone suggested once.
> Alternatively, do you have any idea when this latest build of gdal/ogr will get incorporated into the mapserver binaries download?
I'm afraid I have no control over that, but it is unlikely they will incorporate
the updates until I issue a GDAL 1.3.2 release.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
