write shp files from MS Access MS SQL
william paul williampaul28 at YAHOO.COM
Fri Nov 25 17:58:36 EST 2005
Hello:
  It is possible to write shp files from a MS Access database or a MS SQL database. I am working with both MS Access and MS SQL. I work on a data entry form. Some fields are for geographic coordinates. When the form is submitted I want to write shp file using the fields with the coordinates from the database, so the features appear on the map in real time
  Does someone give me some examples or some links from where I can read more?
  Thank you
  William
 Yahoo! Music Unlimited - Access over 1 million songs. Try it free.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051125/60c06efa/attachment.html
