write shp files from MS Access MS SQL
Bart van den Eijnden
bartvde at XS4ALL.NL
Sat Nov 26 08:01:29 EST 2005
you could do this by setting up an ovf file for your database
connection+table. Then with ogr2ogr you can create a shapefile from it.
Check the following:
-for ovf files (virtual spatial data): http://www.gdal.org/ogr/drv_vrt.html
-for ogr2ogr syntax: http://www.gdal.org/ogr/ogr2ogr.html
There is a php module for OGR, which might be useable for this
(otherwise the next generation SWIG binding for OGR could also be useable):
-for PHP/ogr module: http://dl.maptools.org/dl/php_ogr/
Best regards,
Bart
william paul wrote:
> Hello:
> It is possible to write shp files from a MS Access database or a MS
> SQL database. I am working with both MS Access and MS SQL. I work on a
> data entry form. Some fields are for geographic coordinates. When the
> form is submitted I want to write shp file using the fields with the
> coordinates from the database, so the features appear on the map in
> real time
> Does someone give me some examples or some links from where I can read
> more?
> Thank you
> William
> Yahoo! Music Unlimited - Access over 1 million songs. Try it free.
> <http://pa.yahoo.com/*http://us.rd.yahoo.com/evt=36035/*http://music.yahoo.com/unlimited/>
| Bart van den Eijnden |
| OSGIS, Open Source GIS |
| http://www.osgis.nl |
