Pixmap symbols and transparent
Steve Lime
steve.lime at DNR.STATE.MN.US
Mon Nov 28 08:47:37 EST 2005
You shouldn't have to do that, in fact, I don't believe that option is even used any more. MapServer will use transparency if the image has it. There must be an error in the documentation someplace.
Are you seeing otherwise?
Steve
>>> Stephen Davies <sdc at SDC.COM.AU> 11/28/05 4:27 AM >>>
How does one determine the palette indexes for use with the TRANSPARENT
option in pixmap symbol definitions?
(Why is the transparency of the image file not used?)
Cheers and thanks,
Stephen
This email is for the person(s) identified above, and is confidential to
the sender and the person(s). No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
