error accessing postgis
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Mon Nov 28 11:01:51 EST 2005
By default posgres 8.1 does not build oids any more. You need to change
you query to specify some other unique column for mapserver. You can add
a serial column and make it the primary key then reference that.
-Steve W.
Rick Schumeyer wrote:
> Mapserver [v4.6.1] returns an error when I try to access a postgis
> [1.0.4] database.  (Postgis is installed with postgresql 8.1.0).  I
> assume my mapfile is incorrect, but I’m not sure what the mistake is.
> Here is the error:
> msDrawMap(): Image handling error. Failed to draw layer named 'sdata'.
> prepare_database(): Query error. Error executing POSTGIS DECLARE (the
> actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d(iarea)),'NDR'),OID::text from sdata
> WHERE iarea && setSRID('BOX3D(-180 -135,180 135)'::BOX3D,
> find_srid('','sdata','iarea') )'
> Postgresql reports the error as 'ERROR: column "oid" does not exist '
> The relevant portion of my mapfile:
> LAYER
>      NAME "sdata"
>      CONNECTIONTYPE POSTGIS
>      CONNECTION "dbname=gtest user=postgres host=localhost"
>      DATA "iarea from sdata"
>      TYPE line
>      STATUS default
>      CLASS
>           NAME "State Line"
>           STYLE
>                SYMBOL "BigLine"
>                SIZE 2
>                COLOR 255 0 0
>           END
>      END
> END
> The definition of the table “sdata”:
> Table “public.sdata"
>    Column   |           Type           |                     Modifiers
>  id         | integer                  | not null default
> nextval('sdata_id_seq'::regclass)
>  instrument | character varying(20)    |
>  begintime  | timestamp with time zone |
>  endtime    | timestamp with time zone |
>  iarea      | geometry                 |
>  filename   | character varying(512)   |
> Indexes:
>     "idx_iarea" gist (iarea)
> Check constraints:
>     "enforce_dims_iarea" CHECK (ndims(iarea) = 2)
>     "enforce_geotype_iarea" CHECK (geometrytype(iarea) = 'POLYGON'::text
> OR iarea IS NULL)
>     "enforce_srid_iarea" CHECK (srid(iarea) = 4326)
