error accessing postgis
Mark Cave-Ayland
m.cave-ayland at WEBBASED.CO.UK
Mon Nov 28 11:03:36 EST 2005
Hi Rick,
Under PostgreSQL 8.1 the in-built OID column on user table is deprecated,
and so you must specify a unique column name for Mapserver to use as a
primary key by adding a using unique clause to your data statement, e.g.
DATA iarea from sdata using unique id
Perhaps this is worth mentioning in the FAQ, or even modifying the version
detection code in mappostgis.c so that if PostgreSQL 8.1 is detected then a
more helpful error message can be emitted.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
________________________________________
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Rick Schumeyer
Sent: 28 November 2005 15:46
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] error accessing postgis
Mapserver [v4.6.1] returns an error when I try to access a postgis [1.0.4]
database. (Postgis is installed with postgresql 8.1.0). I assume my
mapfile is incorrect, but Im not sure what the mistake is.
Here is the error:
msDrawMap(): Image handling error. Failed to draw layer named 'sdata'.
prepare_database(): Query error. Error executing POSTGIS DECLARE (the actual
query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(iarea)),'NDR'),OID::text from sdata WHERE
iarea && setSRID('BOX3D(-180 -135,180 135)'::BOX3D,
find_srid('','sdata','iarea') )'
Postgresql reports the error as 'ERROR: column "oid" does not exist '
The relevant portion of my mapfile:
LAYER
NAME "sdata"
CONNECTIONTYPE POSTGIS
CONNECTION "dbname=gtest user=postgres host=localhost"
DATA "iarea from sdata"
TYPE line
STATUS default
CLASS
NAME "State Line"
STYLE
SYMBOL "BigLine"
SIZE 2
COLOR 255 0 0
END
END
END
The definition of the table sdata:
Table public.sdata"
Column | Type | Modifiers
id | integer | not null default
nextval('sdata_id_seq'::regclass)
instrument | character varying(20) |
begintime | timestamp with time zone |
endtime | timestamp with time zone |
iarea | geometry |
filename | character varying(512) |
Indexes:
"idx_iarea" gist (iarea)
Check constraints:
"enforce_dims_iarea" CHECK (ndims(iarea) = 2)
"enforce_geotype_iarea" CHECK (geometrytype(iarea) = 'POLYGON'::text OR
iarea IS NULL)
"enforce_srid_iarea" CHECK (srid(iarea) = 4326)
