Pixmap symbols and transparent
Howard Butler hobu at IASTATE.EDU
Mon Nov 28 16:58:22 EST 2005
Try setting transparency to MS_GD_ALPHA
See http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=926 for some
background.  Some documentation needs to be fixed up...
Howard
At 03:50 PM 11/28/2005, Stephen Davies wrote:
>--Boundary-02=_yu3iDSgVeU0BqTY
>Content-Type: text/plain;
>   charset="iso-8859-1"
>Content-Transfer-Encoding: quoted-printable
>Content-Description: signed data
>Content-Disposition: inline
>I am basing my symbol work on the recent "Construction of Cartographic=20
>Symbols" paper.
>Cheers,
>Stephen
>On Tue, 29 Nov 2005 12:17 am, Steve Lime wrote:
> > You shouldn't have to do that, in fact, I don't believe that option is=20
>even used any more. MapServer will use transparency if the image has=20
>it. There must be an error in the documentation someplace.
> >=20
> > Are you seeing otherwise?
> >=20
> > Steve
> >=20
> > >>> Stephen Davies <sdc at SDC.COM.AU> 11/28/05 4:27 AM >>>
> > How does one determine the palette indexes for use with the=20
>TRANSPARENT=20
> > option in pixmap symbol definitions?
> >=20
> > (Why is the transparency of the image file not used?)
> >=20
> > Cheers and thanks,
> > Stephen
> >=20
> > --=20
> >=20
>=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
> > This email is for the person(s) identified above, and is confidential=20
>to
> > the sender and the person(s).  No one else is authorised to use or
> > disseminate this email or its contents.
> >=20
> > Stephen Davies Consulting                            Voice: 08-8177=20
>1595
> > Adelaide, South Australia.                             Fax: 08-8177=20
>0133
> > Computing & Network solutions.                       Mobile:0403 0405=20
>83
> >=20
> >=20
> >=20
>=2D-=20
>This email is for the person(s) identified above, and is confidential to
>Stephen Davies Consulting                            Voice: 08-8177 1595
>Adelaide, South Australia.                             Fax: 08-8177 0133
>Computing & Network solutions.                       Mobile:0403 0405 83
>Content-Type: application/pgp-signature
>Content-Description: signature
>-----BEGIN PGP SIGNATURE-----
>Version: GnuPG v1.2.2 (GNU/Linux)
>iD8DBQBDi3uydGvWqdjgngARAgyWAJ4mfMfnlMO8YVvLh4f0h/wodax4SgCdG/bi
>bvRXGxHUJ0m5QHIY0wnyQ/4=
>=T+5l
>-----END PGP SIGNATURE-----
>--Boundary-02=_yu3iDSgVeU0BqTY--
