Compiling Mapserver with PostGIS support under Windows
Sture Dingsøyr
candalt at ONLINE.NO
Tue Nov 29 01:55:16 EST 2005
Hi there
This is what i did (i used Visual C++ 6.0):
I did not use the PostgreSQL 8.1 source but the postgresql-8.0.0.
- open CMD
- vcvars32 (this sets the Visual C++ 6.0 environment variables). You will find a vcvars32.bat file under your install directory for Visual C++ 7.0
- enter the postgresql-8.0.0 directory
- cd src
- nmake /f win32.make
This produced under "postgresql-8.0.0\src\interfaces\libpq\Release" a libpq.dll
Thats it :-)
Hello,
I'm attempting to compile Mapserver with support for PostGIS (Postgresql 8.1) using Visual C++ 7. The Mapserver make file requires a version of the Postgresql client "libpqdll.lib" which is where I'm stuck. I've got the Postgresql 8.1 source but have not been able to create libpqdll.lib using VC++. (seems like a problem with linking in appropriate winsock definitions).
As an alternative, I have been able to compile a static version of libpqxx (2.5.5), but haven't been able to get it to link into Mapserver. I've noticed that others are having similar problems, but I've yet to find a solution.
I've used pre-built versions of Mapserver (MS4W and FWTools) sucessfully with Postgresql 8.1/PostGIS, so I know it is possible. If anyone can provide any insight into this problem, I would be much obliged. Perhaps I should be using a different compiler? (Mingw?)
thanks,
Lance Goode
