Default Scale?
Steve Lime steve.lime at DNR.STATE.MN.US
Tue Nov 29 22:33:03 EST 2005
You didn't say if you are using MapScript, the CGI or what. I'll assume MapScript
based on context.
Scale is such an arbitrary thing with web-based mapping. You definitely can't
set SCALE within the mapObj and hope things work. Instead you'll probably need
to compute an extent based on a point and a scale value. To do this you need a couple
of pieces of info:
1) the number of pixels per inch of the output device, MapServer uses 72 internally
2) the number of inches per map unit: for meters that value would be 39.3701
