Default Scale? {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Wed Nov 30 06:42:55 EST 2005
You can set up the original extent of your map through the query string
(URL). For example set maxy and scale (mapxy="12.45 47.56"&scale=100000)
Zoltan
On Tue, 29 Nov 2005, Peter Kingsbury wrote:
> In my mapping application, I'd like to have a default scale to be used
> when the page first loads.
> I've attempted to set this in the map file (e.g. SCALE value in the root
> object) as well as MAXSCALE, however it seems to default to a certain
> aggravating value.
> I've also tried twiddling with the map extents, however this just causes
> the scale to bump up away from my target scale. :)
> Any help is appreciated!
> - P
