Projection & raster questions
Stephen Davies sdc at SDC.COM.AU
Wed Nov 30 22:32:13 EST 2005
Skipped content of type multipart/signed-------------- next part --------------
MAP
  NAME benparts1
  PROJECTION
	"proj=eqc"
	"lon_0=plpl"
  END
  SIZE 600 600
  FONTSET "/usr/local/apache2/htdocs/benparts/fonts.list"
  SYMBOLSET "/usr/local/apache2/htdocs/benparts/symbols"
  UNITS METERS
  IMAGETYPE  png
  IMAGECOLOR 255 255 255
    WEB
	template /usr/local/apache2/htdocs/benparts/templates/test1.html
	imagepath "/usr/local/apache2/htdocs/tmp/"
	imageurl  "/tmp/"
    END
    LEGEND
	KEYSIZE 18 12
	LABEL
	  TYPE BITMAP
	  SIZE MEDIUM
	  COLOR 0 0 94
	END
	STATUS ON
    END
    LAYER
      CONNECTIONTYPE postgis
      NAME "cadt"
      DATA "geom from cad"
      CONNECTION "user=scldad dbname=benparts"
      STATUS DEFAULT
      TYPE POINT
      PROJECTION
        "init=epsg:4263"
      END
      FILTER "gtype='T' and client_id=cidcid"
      CLASSITEM "type"
      CLASS
	EXPRESSION "201"
	STYLE
	  COLOR 0 255 0
	END
	STYLE
	  SYMBOL "tree"
	  COLOR 0 255 0
	  SIZE 9
	END
      END
      CLASS
	EXPRESSION "754"
        LABEL
          MINDISTANCE 150
          POSITION CR
          SIZE TINY
          COLOR 0 0 0
	  FORCE TRUE
        END
	TEXT 'WM'
	STYLE
	  SYMBOL "dot"
	  COLOR 0 0 0
	  SIZE 5
	END
      END
      CLASS
	EXPRESSION "757"
        LABEL
          MINDISTANCE 150
          POSITION CR
          SIZE TINY
          COLOR 0 0 0
	  FORCE TRUE
        END
	TEXT 'Bore'
	STYLE
	  SYMBOL "dot"
	  COLOR 0 0 0
	  SIZE 5
	END
      END
      CLASS
	EXPRESSION "712"
	STYLE
	  SYMBOL "stobie"
	  SIZE 4
	  COLOR 255 0 168
	END
      END
      CLASS
	EXPRESSION /./
        STYLE
	  SYMBOL "dot"
	  COLOR 0 0 0
	  SIZE 5
        END
      END
    END
    LAYER
      NAME "cadl"
      STATUS DEFAULT
      TYPE LINE
      PROJECTION
        "init=epsg:4263"
      END
      FILTER "gtype in ('L','P') and client_id=cidcid"
      CLASSITEM "type"
      CLASS
	EXPRESSION "908"
	STYLE
	  SYMBOL "fence"
	  SIZE 10
	  COLOR 0 255 0
	END
	STYLE
	  SYMBOL "dot"
	  COLOR 0 255 0
	  SIZE 1
	END
      END
      CLASS
	EXPRESSION "712"
	STYLE
	  SYMBOL "power"
	  SIZE 8
	  COLOR 255 0 168
	END
	STYLE
	  SYMBOL "dot"
	  COLOR 255 0 168
	  SIZE 1
	END
      END
      CLASS
	EXPRESSION "602"
        STYLE
	  SYMBOL "dot"
	  COLOR 137 205 190
	  SIZE 1
        END
      END
      CLASS
	EXPRESSION /./
        STYLE
          COLOR        0 0 0
        END
      END
    END
    LAYER
      NAME "probe"
      DATA "geom from probe"
      STATUS DEFAULT
      TYPE POINT
#      FILTER "id in (0)"
      PROJECTION
        "init=epsg:4263"
      END
      MAXSCALE 5000000
      LABELITEM "location"
      CLASS
        NAME       "Probe"
        STYLE
          COLOR        0 214 0
          SYMBOL 'circle'
	  SIZE 7
        END
        LABEL
          MINDISTANCE 150
          POSITION CR
          SIZE SMALL
          COLOR 0 0 0
        END
      END
    END
  # Start of reference map
  REFERENCE
    IMAGE /usr/local/apache2/htdocs/benparts/refmaps/ixix
    EXTENT exex
    SIZE 120 120
    STATUS ON
    MINBOXSIZE 5
    MAXBOXSIZE 100
    COLOR 0 255 0
    OUTLINECOLOR 0 0 0
    MARKERSIZE 8
    MARKER 'star'
  END
  # Start of scalebar
  SCALEBAR
    IMAGECOLOR 0 0 0
    LABEL
      COLOR 255 255 255
      SIZE TINY
    END
    STYLE 1
    SIZE 200 2
    COLOR 255 255 255
    UNITS KILOMETERS
    INTERVALS 2
    TRANSPARENT TRUE
    STATUS ON
  END
END
MAP
  NAME test
  PROJECTION
   "init=epsg:4263"
  END
#  PROJECTION
#	"proj=eqc"
#        "lon_0=112.5e"
#  END
    EXTENT 112.5 -44.0933134 153.78 -8.9033134
#    EXTENT 135.5 -40.0933134 143.78 -28.9033134
#     EXTENT 139.357482910156 -34.3308868408203 139.380233764648 -34.3129386901855
#    EXTENT 0 -5000000 4200000 0
  SIZE 600 600
  SHAPEPATH "/benparts/rasters"
  UNITS METERS
  IMAGETYPE  png
    OUTPUTFORMAT
	NAME ecw
	DRIVER "GDAL/ECW"
	MIMETYPE "image/ecw"
	IMAGEMODE PC256
	EXTENSION "ecw"
    END
    WEB
	imageurl  "/tmp/"
    END
    LAYER
      TYPE RASTER
      NAME "bkgrnd"
      STATUS DEFAULT
      DATA "/tmp/ls7_mosaic.ecw"
      PROJECTION
        "init=epsg:4283"
      END
      OFFSITE 255 255 255
    END
END
