MAXTEMPLATE and MINTEMPLATE
Daniele Margotti
margottid at COMUNE.LUGO.RA.IT
Mon Oct 3 06:41:50 EDT 2005
Hi list,
how can I use MAXTEMPLATE and MINTEMPLATE in a .map file?
When I set a MAXTEMPLATE parameter, in WEB section of a mapfile, I get
an error when I browse a map out of max scale factor:
[Mon Oct 03 12:06:39 2005] [error] [client 127.0.0.1] malformed
header from script. Bad header=<html>: mapserv, referer:
<http://localhost/cgi-bin/mapserv> http://localhost/cgi-bin/mapserv
(The same thing happens with MINTEMPLATE).
In my mapfile I tried to use the same template of the "normal" view:
WEB
MAXSCALE 150000
TEMPLATE "template.html"
MAXTEMPLATE "template.html"
END
Is the template of MAXTEMPLATE structured as the one of TEMPLATE?
Or are they differently structured?
Thank you,
Daniele
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051003/5561d011/attachment.html
