Sid complie
    Eric Shuman
    erics at AMERI-TITLE.COM
    Tue Oct  4 15:03:37 PDT 2005
It seems my install of mapserver (via FGS) doesn't support sid, and I have a
large sid image that if converted to tiff will be over 20gigs in size.  (I
could tile it but it would still take up a lot of space)   How hard is it to
include sid?  Will this cause problems with the FGS setup?  What is the
procedure?  I'm fairly green when it comes to linux so if I could get the
"For Dummies" explanation it would be helpful!
Thanks,  Eric
* OS: FEDORA CORE 3
* FGS API version :
*       NAME                         VERSION
*       apache-base                     1.3.33
*       curl-lib                        7.12.2
*       expat-base                      1.95.8
*       freetype-lib                    2.1.9
*       gdal-base                       1.2.5
*       gd-lib                          2.0.33
*       geos-lib                        1.0.0
*       jpeg-lib                        6b
*       libgeotiff-lib                  1.2.2
*       libiconv-base                   1.9.1
*       libpng-lib                      1.2.6
*       libungif-base                   4.1.3
*       mapserver-base                  4.4.1
*       mapserver-php                   4.4.1
*       netcdf-lib                      3.5.1
*       openssl-lib                     0.9.7d
*       php-base                        4.3.10
*       postgis-lib                     1.0.0
*       postgresql-lib                  7.4.7
*       postgresql-server               7.4.7
*       proj4_epsg42xxx-support         1.0.0
*       proj-lib                        4.4.8
*       tiff-lib                        3.7.1
*       unixODBC-base                   2.2.10
*       xerces_c-base                   2_6_0
More information about the MapServer-users
