GDAL/OGR 1.3.1 Released
Tamas Szekeres
szekeres.tamas at FREEMAIL.HU
Thu Oct 6 10:36:27 EDT 2005
Frank,
Thank you for the release. However in order to compile SWIG with C# some
modifications should be made in the makefile and some typemaps should be
added.
Tamas
On Tue, 4 Oct 2005 15:32:51 -0400, Frank Warmerdam <warmerdam at POBOX.COM>
wrote:
>Folks,
>I am pleased to announce the release of GDAL/OGR 1.3.1. This is mostly a
>bug fix release, though there are a few new and improved drivers.
>Source:
> http://www.gdal.org/dl/gdal-1.3.1.tar.gz
> http://www.gdal.org/dl/gdal131.zip
>Docs / Web site:
> http://www.gdal.org/dl/gdal131doc.zip
>Test Suite:
> http://www.gdal.org/dl/gdalautotest-1.3.1.tar.gz
>The major news with this release is that the "Next Generation" Perl,
Python
>and Ruby bindings are now considered ready to use, though I'm sure there
will
>be some additional improvements to them in the coming months. I would
like to
>give out a special thank you to Ari Jolma (perl), Charlie Savage (Ruby),
>Kevin Ruland (Python + overall NG work) and Howard Butler who have put in
a
>huge amount of effort on these bindings. If we can get champions for
Java,
>C# and PHP that are willing to brave the dark depths of SWIG, I'm sure we
can
>make good progress on them too.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
>GDAL 1.3.1 - Overview of Changes
>Next Generation SWIG Wrappers (GDAL and OGR):
> - Python, Perl and Ruby bindings considered to be ready to use.
> - C#, Java, PHP are at best initial prototypes.
> - Added configure options for most NG options.
>PCRaster Driver:
> - libcsf is now included as part of GDAL.
> - PCRaster enabled by default on win32.
> - --with-pcraster=internal option now supported on unix (but not yet
default)
>VSI Virtualization:
> - The "large file API" (VSI*L) has been re-engineered to allow installing
> additional file handlers at runtime.
> - Added "in memory" VSI handler so that now any driver using VSI*L
> functions for data access can operate on in-memory files.
> - PNG, JPEG and GeoTIFF drivers upgraded to work with in-memory support.
>Raster Attribute Tables:
> - Implemented new Raster Attribute Tables support. See the
> GDALRasterAttributeTable class for more information.
>Erdas Imagine Overviews:
> - Erdas Imagine driver upgraded to support building internal overviews.
> - Generic overview handler updated to support overviews in Erdas Imagine
> format for any file format. Set USE_RRD config option to YES to
enable.
>gdalwarp:
> - Added proper support for "unified source nodata", so the -srcnodata
> switch works well.
>RIK Driver:
> - New Swedish format driver implemented by Daniel Wallner.
>JPEG Driver:
> - Substantial improvements to EXIF support.
>MrSID Driver:
> - Updated with proper JPEG2000 support as JP2MRSID driver, including
> encoding with ESDK.
> - Updated to support MrSID Version 5.x SDKs.
>PNG Driver:
> - Fixed serious bugs with 16bit file support.
> - Added NODATA_VALUES to identify RGB sets that indicate a nodata pixel.
>OGR 1.3.1 - Overview of Changes
>Reference Counting:
> - OGRSpatialReference and OGRFeatureDefn now honour reference counting
> semantics.
> - Note that, especially for the OGRFeatureDefn, it is now critical that
> all drivers be careful with reference counting. Any OGR drivers not in
> the core distribution will likely crash if not updated.
>ESRI Personal Geodatabase Driver:
> - New driver implemented for ESRI Personal Geodatabase (.mdb) files.
> - Uses ODBC, enabled by default on win32.
>ODBC Driver:
> - Updated to support binary fields.
> - Updated to support WKB geometry fields.
> - Updated to support DSN-less connections.
>S57 Driver:
> - Added support for Inland Waterways, and Additional Military Layers
profiles
