Need some help on WMS server.
Fawcett, David
David.Fawcett at STATE.MN.US
Mon Oct 10 14:15:01 EDT 2005
Paul,
I am guessing that you are getting the same image every time because you
have all three layers STATUS set to default. Therefore, however you
request it, all three layers are drawing and the last one in your map
file is being drawn on top.
I would suggest setting the layers STATUS to ON, and then using the
layers parameter in your GetMap request to select the layer that you are
interested in.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Paul Turner
Sent: Monday, October 10, 2005 11:36 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Need some help on WMS server.
I'm bringing up a WMS server and I'm having problems serving different
images from the same map file. It looks like only the last image of the
3 is being served.
The server is at
http://www.ccalmr.ogi.edu/cgi-bin/mapserv?map=/usr/local/apache/mapserve
r/wms.map
There are 3 images served, one per layer, and each is different (I've
verified this) but it seems that in every WMS client I use, the same
image shows up no matter which layer I select (the last image).
Any suggestions appreciated.
Thx,
--Paul
Paul J Turner
OHSU-OGI-CCALMR
mapserver CGI is configured thusly:
/usr/local/apache/cgi-bin) mapserv -v
MapServer version 4.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
Here is the map file:
MAP
NAME "CORIE Dev Forecast"
DEBUG ON
# SIZE 550 450
# IMAGETYPE GIF
UNITS DD
EXTENT -125.300000 45.300000 -122.844754 47.299633
WEB
LOG "/tmp/mapserver.log"
IMAGEPATH "/usr/local/apache/htdocs/ms/tmp"
IMAGEURL "/ms/tmp/"
METADATA
"wms_title" "CORIE WMS Service"
"wms_onlineresource"
"http://www.ccalmr.ogi.edu/cgi-bin/mapserv?map=/usr/local/apache/mapserv
er/wms.map&"
##required
"wms_srs" "epsg:4326"
"wms_format" "image/gif"
END
END
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "devforecast1"
STATUS DEFAULT
DUMP TRUE
METADATA
"wms_title" "DevForecast 1" ##required
"gml_include_items" "all"
END
TYPE RASTER
DATA
"/usr/local/apache/mapserver/llcolsal_plume_surface_000090000.gif"
PROJECTION
"init=epsg:4326" ##recommended
END
END
LAYER
NAME "devforecast2"
STATUS DEFAULT
DUMP TRUE
METADATA
"wms_title" "DevForecast 2" ##required
END
TYPE RASTER
DATA
"/usr/local/apache/mapserver/llcolsal_plume_surface_000093600.gif"
PROJECTION
END
END
LAYER
NAME "devforecast3"
STATUS DEFAULT
DUMP TRUE
METADATA
"wms_title" "DevForecast 3" ##required
END
TYPE RASTER
DATA
"/usr/local/apache/mapserver/llcolsal_plume_surface_000097200.gif"
PROJECTION
END
END
END
The images can be seen at (warning, 2048x2048):
http://www.ccalmr.ogi.edu/ms/llcolsal_plume_surface_000090000.gif
http://www.ccalmr.ogi.edu/ms/llcolsal_plume_surface_000093600.gif
http://www.ccalmr.ogi.edu/ms/llcolsal_plume_surface_000097200.gif
