time series problem
Jeroen Ticheler
Jeroen.Ticheler at FAO.ORG
Tue Oct 11 13:20:58 EDT 2005
I have a problem with time series for WMS. I have used the following
WMS attributes in my map file and I get the default image the first
WMS map request. The moment I start requesting maps with the time
variable set, I get an exception indicating that the time format used
is not correct.
The data is GeoTIFF
I have an index shapefile with an imgdate column containing the dates
in the same format
Anyone an idea, I can't find an example that has a whole range of
images with a specific time set for each image.
Map file extract:
At the map level (although I don't think this is supported/needed for
GeoTIFF data!?)
____________________________
"wms_timeformat" "YYYY-MM-DD"
At the layer level
"wms_style_default_title" "default"
"wms_format" "image/png"
"wms_timedefault" "2005-09-11"
"wms_timeextent"
"2005-08-21,2005-09-01,2005-09-11" # also tried with spaces
after each comma
"wms_timeitem" "imgdate"
END
DUMP TRUE
TILEINDEX 'ndvi_idx'
TILEITEM "location"
EXTENT -180.0 -90.0 180.0 90.0
PROJECTION "init=epsg:4326" END
Thanks in advance,
Jeroen
Jeroen Ticheler
FAO-UN
Tel: +39 06 57056041
http://www.fao.org/geonetwork
12.34327°N 12.34327°E
