Problems with ArcInfo Binary grid...
Frank Warmerdam warmerdam at POBOX.COM
Tue Oct 11 13:53:25 EDT 2005
On 10/10/05, Carlo Calvino <carlo.calvino at> wrote:
> On Wed, 5 Oct 2005 10:53:25 -0400, Frank Warmerdam <warmerdam at POBOX.COM>
> wrote:
> >Yes, .clr files *should* work and mapserver should color the raster
> >according to the .clr file if is present.  You can check quickly whether
> >the colortable is found by using gdalinfo on the binary grid.
> Thank you very much for your help. You are right, mapserver *seems* to
> support .clr files if present. I made such a file with ArcView8, and
> tested it both with gdalinfo and postgis. But when I view it as a
> mapserver map, only red colors are visible (but there are other colors!).
> Do you have any idea ?
What does the "gdalinfo" report of the coverage look like?
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at
light and sound - activate the windows |
