FW: [UMN_MAPSERVER-USERS] Performance Difference between 3.6.
and 4.6
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Wed Oct 12 18:49:51 EDT 2005
Are there any visual differences in your map output? The reason I ask is
perhaps labels in 4.6 are being drawn with not vector fonts. Otherwise I
don't see any reasons why 4.6 would be slower. 256MB of RAM is pretty
tiny prehaps the SuSe distro is tieing up more system resources causing
significant swapping.
-e
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Steve Young
Sent: Wednesday, October 12, 2005 4:39 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] FW: [UMN_MAPSERVER-USERS]
Performance Difference between 3.6. and 4.6
Here's the -v. I recompiled v 4.6.1 with fewer options, but to
no noticable difference. I can post its latest incarnation tomorrow.
Steve
MapServer version 3.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF
INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
MapServer version 4.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=THREADS INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
From: Ethan Alpert [mailto:ealpert at digitalglobe.com]
Sent: October 12, 2005 3:29 PM
To: Steve Young
Subject: RE: [UMN_MAPSERVER-USERS] Performance Difference
It might be helpful to post the outputs of
mapserv -v
for 3.6 and 4.6
[mailto:MAPSERVER-USERS at lists.umn.edu] On Behalf Of Steve Young
Sent: Wednesday, October 12, 2005 3:28 PM
To: MAPSERVER-USERS at lists.umn.edu
Subject: [UMN_MAPSERVER-USERS] Performance Difference
This is a repost from a couple of weeks ago. I could
still do with some advice/info so rephrasing.
Can anyone tell me if I should expect a decrease in
speed of image rendering moving from version 3.6 to 4.6? Currently when
displaying tileindexed layer of approximately 200 shapefiles I get a big
performance hit. With 3.6 images are drawn in 2s or less, with 4.6 its
4s or more depending on the number of arcs being displayed. Both
datasets have been shptree'd and sortshp'd using their associated
executables. There are hardware differences, they both have 256Mb RAM
otherwise the 4.6 machine has a faster CPU and HD. 3.6 machine is
running on RH Linux 7 Apache 1.3. 4.6 machine is running Suse 9.1,
Apache2
Should I expect any performance differences between
Apache 1.3 and 2?
I've tried compiling 3.6.1 to run on the same machine as
4.6 version, but I'm getting an "undefined reference to
`__gxx_personality_v0'" error message on make. Looks to be something to
do with gcc and g++, but I haven't been able to find a solution. I'm not
convinced I'm on the right path, so any advice the list can give is
appreciated.
Steve
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051012/763f93be/attachment.html
