time series problem 3 (Bug!?)
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu Oct 13 18:37:43 EDT 2005
From the specs (wms 1.1 annex c c.3), the extent could be defined in 4
ways :
1) value : A single value. This is not directly supported in
Mapserver but there is an easy workwound by specifying the same value as
min and max
2) value1,value2,value3,... a A list of multiple values. This is not
supported in Mapserver.
3) min/max/resolution An interval defined by its lower and upper
bounds and its resolution. This is supported in Mapserver (Note
that the resolution is not supported)
4) min1/max1/res1,min2/max2/res2,... a A list of multiple intervals.
Not supported
I am willing to add the support for number 4) if you are willing to do
additional testing.
I am not sure if 2) is is a must have at this point.
Le me know what you think and then we can proceed with the impentation.
Later,
Jeroen Ticheler wrote:
> Thanks for that! Is it a complex thing to add such support? I had the
> impression from the code that it was virtually there already, just that
> it first checked for a range and does not proceed to check for ranges?
> The problem is that a range doesn't work for this series. Data comes in
> at three 10 daily periods a month, which is not exactly true as a month
> does not always have 30 days. Still the images are always dated with a
> 01, 11 and 21 for the day (or 1,2 or 3 for a dekad).
> Ciao,
> Jeroen
> _______________________
> Jeroen Ticheler
> FAO-UN
> Tel: +39 06 57056041
> http://www.fao.org/geonetwork
> 42.07436°N 12.34327°E
> On 13 Oct 2005, at 20:03, Yewondwossen Assefa wrote:
>> Hi There,
>> Sorry for the late answer.
>> From what I can see in your examples, you are running into a
>> limitation of mapserver and it's support for the time extent values.
>> Currently the time extent can only be defined as a range value and
>> only one range value is valid (so something like is the only thing
>> valid 2005-09-11/2005-09-21)
>> You should update your "wms_timeextent" and try it with only one
>> range. I will enter documentation bug so that this limitation is
>> clearly defined. Give it a try and let me know.
>> Later,
>>> Hi, sorry for continuing this story, but I really want to solve
>>> this and hope my additional info helps to sort out the problems I
>>> face.
>>> I am using a shapefile with the imgdate column added to it. I use
>>> exactly the same index to work with a WCS on the same data, that
>>> one works perfectly fine.
>>> I have browsed through the mapServer sourcecode to see if I could
>>> discover something/ understand the problem better. I'm not familiar
>>> with C coding, so forgive my ignorance :-) What I could understand
>>> is that my request fails when the time string submitted in the
>>> request is compared to the timeextent given in the capabilities
>>> document.
>>> The exact section of the code is in between line 545 and line 569,
>>> apparently the msValidateTimeValue() procedure fails to find the
>>> requested date in the extent. I do not get an error when I change
>>> my extent to a range like "2005-09-11,2005-09-21/2005-09-21" or
>>> "2005-09-11,2005-09-11/2005-09-21", but it will only render the
>>> very last image, even when an earlier one is requested.
>>> So I guess I face a bug!?
>>> Thanks again,
>>> Jeroen
>>> Begin forwarded message:
>>>> From: Jeroen Ticheler <Jeroen.Ticheler at FAO.ORG>
>>>> Date: 12 October 2005 09:54:26 GMT+02:00
>>>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>>>> Subject: [UMN_MAPSERVER-USERS] time series problem 2
>>>> Reply-To: Jeroen Ticheler <Jeroen.Ticheler at FAO.ORG>
>>>> Further to my previous message, the exception I get is the
>>>> following one:
>>>> <ServiceExceptionReport version="1.1.1">
>>>> <ServiceException code="InvalidDimensionValue">
>>>> msWMSApplyTime: WMS server error. Time value(s) 2005-09-21 given
>>>> is invalid or outside the time extent defined
>>>> (2005-03-11,2005-03-21,2005-04-01,2005-04-11,2005-04-21,2005-05-01,2
>>>> 00
>>>> 5-05-11,2005-05-21,2005-06-01,2005-06-11,2005-06-21,2005-07-01,2005-
>>>> 07
>>>> -11,2005-07-21,2005-08-01,2005-08-11,2005-08-21,2005-09-01,2005-09-1
>>>> 1, 2005-09-21), and default time set is invalid (2005-09-21)
>>>> </ServiceException>
>>>> </ServiceExceptionReport>
>>>> And the URL's I use are:
>>>> For Capabilities:
>>>> http://193.43.36.137/cgi-bin/spotveg?
>>>> version=1.1.1&service=WMS&request=GetCapabilities
>>>> For a working map without specifying the time:
>>>> version=1.1.1&service=WMS&request=GetMap&srs=EPSG:
>>>> 4326&bbox=-180,-90,180,90&format=image/
>>>> png&layers=spotndvi&transparent=true&width=400&height=200
>>>> For a request with a time, the exception is returned:
>>>> png&layers=spotndvi&transparent=true&width=400&height=200&time=2005-
>>>> 09 -21
>>>> These URL's can be reached from outside, so you can try this yourself.
>>>> Thanks in advance for any help to a solution,
>>>> Jeroen
>>>> On 11 Oct 2005, at 19:20, Jeroen Ticheler wrote:
>>>>> Hi,
>>>>> I have a problem with time series for WMS. I have used the
>>>>> following WMS attributes in my map file and I get the default
>>>>> image the first WMS map request. The moment I start requesting
>>>>> maps with the time variable set, I get an exception indicating
>>>>> that the time format used is not correct.
>>>>> The data is GeoTIFF
>>>>> I have an index shapefile with an imgdate column containing the
>>>>> dates in the same format
>>>>> Anyone an idea, I can't find an example that has a whole range of
>>>>> images with a specific time set for each image.
>>>>> Map file extract:
>>>>> At the map level (although I don't think this is supported/ needed
>>>>> for GeoTIFF data!?)
>>>>> ____________________________
>>>>> "wms_timeformat" "YYYY-MM-DD"
>>>>> At the layer level
>>>>> "wms_style_default_title" "default"
>>>>> "wms_format" "image/png"
>>>>> "wms_timedefault" "2005-09-11"
>>>>> "wms_timeextent"
>>>>> "2005-08-21,2005-09-01,2005-09-11" # also tried with
>>>>> spaces after each comma
>>>>> "wms_timeitem" "imgdate"
>>>>> END
>>>>> DUMP TRUE
>>>>> TILEINDEX 'ndvi_idx'
>>>>> TILEITEM "location"
>>>>> EXTENT -180.0 -90.0 180.0 90.0
>>>>> PROJECTION "init=epsg:4326" END
>>>>> Thanks in advance,
>>>>> Jeroen
>>>>> Jeroen Ticheler
>>>>> FAO-UN
>>>>> 12.34327°N 12.34327°E
>> Assefa Yewondwossen
>> Software Analyst
>> Email: assefa at dmsolutions.ca
>> http://www.dmsolutions.ca/
>> Phone: (613) 565-5056 (ext 14)
>> Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
