google maps projection
John Hagstrand
john.hagstrand at INTERAGERESEARCH.COM
Fri Oct 14 03:21:31 EDT 2005
Thanks, Ed. You were right. It works great. Thanks also to Stephen
Woodbridge who supplied the projection information.
John
>On Wed, 12 Oct 2005, Ed McNierney <ed at TOPOZONE.COM> wrote:
>I'd suggest the following...
> proj=merc
> lat_ts=0.0
> lon_0=-90.0
> x_0=0.0
> y_0=0.0
> ellps=GRS80
> units=m
> no_defs
>>-----Original Message-----
>>I've been told that:
>>Google Maps uses the Mercator projection and the WGS 84 geodetic datum.
>>The projection standard latitude is 0, and the projection standard
>>longitude is -90.
>>How can I translate that to a MapServer Projection block?
