[GRASSLIST:8620] Re: GRASS, gdal and mapserver
Francisco Alonso
alonsarp at UM.ES
Thu Oct 13 14:56:03 EDT 2005
> On 10/13/05, Francisco Alonso <alonsarp at um.es> wrote:
> > El Viernes, 14 de Octubre de 2005 10:25, Radim Blazek escribió:
> > > On 10/12/05, Francisco Alonso <alonsarp at um.es> wrote:
> > > > # ogrinfo
> > > > /var/www/grass5_mapserver/spearfish60/PERMANENT/vector/streams/head
> > > > Warning 1: GRASS warning: GISBASE enviroment variable was not set,
> > > > using: /usr/local/grass-6.0.1
> > > > ogrinfo: relocation error: /usr/local/lib/gdalplugins/ogr_GRASS.so:
> > > > undefined symbol: Vect_set_fatal_error
Ok I have it.
After realizing that
# ldd ogr_GRASS.so
didn't mention the grass vector library I remembered that I had linked just
the grass libraries needed by gdal. On the other hand the makefile I obtained
with:
./configure --with-gdal=/usr/local/bin/gdal-config
--with-grass=/usr/local/grass-6.0.1
doesn't include any -lgrass_vect, so I put it myself just to try.
After that ldd ogr_GRASS .so did complain about libgrass_vect. I linked it,
and after some more links and incluiding -lgrass_dbmidriver in the LIBS line
of the Makefile I have ogrinfo working properly:
# ogrinfo /var/www/grass5_mapserver/spearfish60/PERMANENT/vector/streams/head
Warning 1: GRASS warning: GISBASE enviroment variable was not set, using:
INFO: Open of
`/var/www/grass5_mapserver/spearfish60/PERMANENT/vector/streams/head'
using driver `GRASS' successful.
1: 0
2: 1
Thanks a lot for your suggestions.
I am still working on my other problem (mapserver not showing GRASS raster
files that gdal can read)
I tried to gdal_translate the spearfish soils layer to pcraster and reading it
with mapserver (ugly colours but it worked) so it seem that grass-gdal
connection works and mapserver-gdal also works.
And now I have changed the roads layer definition in the map file to read the
roads grass layer instead of shape (I'm workig with spearfish demo):
LAYER
NAME roads
TYPE LINE
STATUS DEFAULT
DATA /var/www/grass5_mapserver/spearfish60/PERMANENT/vector/roads/head
TOLERANCE 5
LABELITEM CAT_ID
TEMPLATE /var/www/grass5_mapserver/spearfish/roads.html
# OFFSITE 0
CLASS
NAME "Road"
COLOR 80 80 80
LABEL
POSITION CC
SIZE SMALL
COLOR 0 0 225
END
END
END
but I have a prettty similar error message
# /usr/local/mapserver-4.6.1/shp2img -m
/var/www/grass5_mapserver/map-script/mapserver.map -o mapa.png
msDrawMap(): Image handling error. Failed to draw layer named 'roads'. <br>
msSHPOpenFile(): Unable to access file.
(/var/www/grass5_mapserver/spearfish60/PERMANENT/vector/roads/head) <br>
but the file DO exist, do I need to specify in any way that it is a GRASS
file?
Do you know where you can download the files of the demo 2 accesible from
http://grass.itc.it/start.html ?
I will continue trying, but if anyone has suggestions ....
Paco
Francisco Alonso Sarría
Departamento de Geografía (Area de Geografía Física)
Universidad de Murcia. Campus La Merced
E-30001 Murcia
Telfn: +34 968364357
www.um.es/geograf/sigmur
