Querying the extents of a layer (shapefile)
Chip Taylor work at XWB.COM
Fri Oct 14 10:37:33 EDT 2005
Here is what we want to do:
1. Map is of US, showing boundaries of the states
2. User selects a point within a state
3. Map redraws, centered on state with extents changed to match that of the
state layer (state shapefile) with all other layers disabled.
Chip Taylor
Prepared Response, Inc.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Fawcett, David
> Sent: Friday, October 14, 2005 6:18 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Querying the extents of a layer
> (shapefile)
> I would suggest that you give us a little more info.  Lay out what you
> are trying to do, most likely, someone will have an idea of how to get
> you there.
> David.
> From: work at XWB.COM [mailto:work at XWB.COM]
> Sent: Thursday, October 13, 2005 4:40 PM
> To: 'Fawcett, David'; MAPSERVER-USERS at lists.umn.edu
> Subject: RE: [UMN_MAPSERVER-USERS] Querying the extents of a layer
> (shapefile)
> Thanks,
>   I have done that before but I can only do that manually.  I need a
> method either inside of Mapserver, in VBScript in an ASPX page, in
> Javascript in the Template page, or PHP to do this and then pass it to
> Mapserver to render the next map.
> Chip Taylor
> > From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
> > Sent: Thursday, October 13, 2005 1:12 PM
> > To: work at XWB.COM; MAPSERVER-USERS at lists.umn.edu
> > (shapefile)
> > You can run ogrinfo on it and get the extents
> > http://ogr.maptools.org/ogr_utilities.html
> > On Behalf Of Chip Taylor
> > Sent: Thursday, October 13, 2005 2:34 PM
> > Subject: [UMN_MAPSERVER-USERS] Querying the extents of a layer
> > (shapefile)
> > If I have a shapefile as a layer can I query the extents of that
> > shapefile from MapServer or MapScript?
> > Thanks for all the help you give to us poor newbies.
> > Chip Taylor
