Querying the extents of a layer (shapefile)
Alexander Gabriel
alexander.gabriel at DIGITAL-INFINITY.DE
Fri Oct 14 08:28:42 EDT 2005
use $oLayer->getExtent() in PHP.
http://mapserver.gis.umn.edu/doc46/phpmapscript-class-guide.html#LayerObj
Alexander
On Thu, 13 Oct 2005 23:39:45 +0200, Chip Taylor <work at XWB.COM> wrote:
> Thanks,
> I have done that before but I can only do that manually. I need a
> method
> either inside of Mapserver, in VBScript in an ASPX page, in Javascript in
> the Template page, or PHP to do this and then pass it to Mapserver to
> render
> the next map.
> Chip Taylor
> Prepared Response, Inc.
>> -----Original Message-----
>> From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
>> Sent: Thursday, October 13, 2005 1:12 PM
>> To: work at XWB.COM; MAPSERVER-USERS at lists.umn.edu
>> Subject: RE: [UMN_MAPSERVER-USERS] Querying the extents of a layer
>> (shapefile)
>> You can run ogrinfo on it and get the extents
>> http://ogr.maptools.org/ogr_utilities.html
>> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
>> Behalf Of Chip Taylor
>> Sent: Thursday, October 13, 2005 2:34 PM
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: [UMN_MAPSERVER-USERS] Querying the extents of a layer
>> (shapefile)
>> If I have a shapefile as a layer can I query the extents of that
>> shapefile from MapServer or MapScript?
>> Thanks for all the help you give to us poor newbies.
>> Chip Taylor
