MINSCALE MAXSCALE USE in grouped layers
Gregory Yetman
gyetman at CIESIN.COLUMBIA.EDU
Fri Oct 14 15:19:37 EDT 2005
Hi Glen,
I had issues with this setting up a series of image layers as well.
MINSCALE is the largest scale that the layer will be rendered at,
MAXSCALE is the smallest scale that it will be rendered at. This is a
bit confusing if you are used to cartographic conventions (i.e.,
MINSCALE would be the smallest scale). There was a good post by Ed
McNierney on how the scale is calculated based on the display at little
while ago, it helped us calculate what scales to use (a belated thanks
to Ed). Ed's posts are available at:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0208/msg00056.html
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0211/msg00186.html
Greg
