Tileindex problem
Frederic Claudel fclaudel at CSIR.CO.ZA
Mon Oct 17 09:56:29 EDT 2005
Have you checked your SHAPEPATH tag in the MAP object?:
MAP
   NAME "MyMap"
   SHAPEPATH "/home/mydata"
the path will be preprended to the tiles' paths listed in the shapefile
hope it helps,
Frederic
>>> Eros Agosto <eros.agosto at POLITO.IT> 17/10/2005 13:00 >>>
Hi List,
I have a problem in using tileindex
I mean:
if I display a raster file (tiff+tfw) it shows: OK
DATA "IGN_50000/psc_3124.tif"
TYPE RASTER
if I display a group of rasters (including the previous one) with tileindex:
Nothing is showed (except the class name in the legend)
TILEINDEX 'IGN_50000/IGN_50000.shp'
TILEITEM 'location'
 TYPE RASTER
I checked the 'location' field in the tileindex file, I checked the position
of raster files, but it seems OK
Any idea?
Thanks a lot
Eros
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, May 20, 2005 12:19 AM
Subject: Re: [UMN_MAPSERVER-USERS] Image Tiling
I use imagemagick and gdal_translate to split and build tiles from large
images. Then I build a tile index with gdaltindex. As long as you tile
index layers MIN/MAX scales are set right you get a pretty big
performance gain. However if you're rendering many of the tiles in the
same image it slows down. I create overviews for large scales and
display those and have the tile index only come on at lower scales.
-e
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Greg Taylor
Sent: Thursday, May 19, 2005 1:42 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Image Tiling
What kind of programs/scripts do most of you use to tile .tif images?
I'd be interested in playing with this. Do any of you that use tiled
images notice an improvement in performance?
This message is subject to the CSIR's copyright, terms and conditions and
e-mail legal notice. Views expressed herein do not necessarily represent the
views of the CSIR.
CSIR E-mail Legal Notice
http://mail.csir.co.za/CSIR_eMail_Legal_Notice.html
CSIR Copyright, Terms and Conditions
http://mail.csir.co.za/CSIR_Copyright.html
For electronic copies of the CSIR Copyright, Terms and Conditions and the CSIR
Legal Notice send a blank message with REQUEST LEGAL in the subject line to
HelpDesk at csir.co.za.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean.  MailScanner thanks Transtec Computers for their support.
