WCS: server fails with a small coverage
Steve Lime
steve.lime at DNR.STATE.MN.US
Wed Oct 19 12:24:01 EDT 2005
The WCS server doesn't (I'm pretty sure) honor MAXSCALE or MINSCALE. I'm trying to think of how it even could- WCS is supposed to provide unfiltered access to raster data (unless resampling is explicitly requested). I can compute a display scale for an image of a certain size but that's a generally meaningless number used for turning stuff on and off. I don't think it is a good way to control the production of large datasets. Is that what you're hoping to use it for? If so I think maximum image dimensions are a better alternative.
Steve
>>> José Vte Higón <higon_jos at GVA.ES> 10/19/05 6:57 AM >>>
Hi,thanks for yours answers.
We are investigating about this problem.Our client must treat this issue.
But... why doesn't work MAXSCALE?
This is the mapfile:
MAP
NAME 'prueba_wcs'
EXTENT 742806.4 4264938.3 753600.4 4268018.3
DEBUG ON
IMAGETYPE PNG
#IMAGECOLOR 0 0 0
UNITS METERS
OUTPUTFORMAT
NAME GEOTIFF_INT16
DRIVER "GDAL/GTiff"
IMAGEMODE INT16
EXTENSION "tif"
END
WEB
TEMPLATE "."
MAXSCALE 1000000
METADATA
"wcs_label" "Servidor pruebas wcs"
"wcs_keywordlist" "WCS"
"wcs_onlineresource" "http://gruposigp2/cgi-bin/wcs"
END
LOG "/usr/local/mapserver/wcs.log"
IMAGEURL "/usr/local/mapserver/tmp/"
IMAGEPATH "/usr/local/mapserver/tmp/"
END
PROJECTION
"init=epsg:32630"
END
LAYER
NAME "quickbird3"
STATUS ON
TYPE RASTER
PROCESSING "SCALE=AUTO"
PROCESSING "BANDS=1,2,3"
UNITS METERS
MAXSCALE 500000
METADATA
wcs_name "quickbird3"
wcs_label "Quickbird R2C2"
ows_srs "EPSG:32630"
ows_extent "742806.4 4264938.3 753600.4 4268018.3"
wcs_resolution "0.7 0.7"
wcs_formats "GEOTIFF_INT16"
wcs_nativeformat "raw_binary"
wcs_rangeset_axes "bands"
wcs_rangeset_label "bands"
wcs_rangeset_name "bands"
wcs_bandcount "3"
END
PROJECTION
"init=epsg:32630"
END
DUMP TRUE
DATA '/home/data/quickbird/221_r2c2_zona.tif'
END
END #map
