PHPMapscript/Linux horrible performance after Apache 1.3->2.0
upgrade
Hal Mueller
halmueller at GMAIL.COM
Wed Oct 19 18:47:28 EDT 2005
My hosting company just surprised me with an "upgrade" from Apache 1.3
to Apache 2.0, as part of a solution to some other problems. After
reinstalling Mapserver, I am seeing performance that is less than a
tenth of what I had before. Server is running Redhat Enterprise
Edition behind an Ensim virtual hosting package.
I've gone through installation carefully, and I think I have
everything right. But when I reinstalled Mapserver I updated several
supporting libraries. I want to make sure I'm barking up the right
tree. I suspect Apache is the problem. Am running PHP as a separate
CGI.
What I am seeing when I run "top" is that the PHPCGI processes take
over the machine. This didn't happen before. I had a steady system
load of about 0.7 and was able to service all requests; now I see a
server load of 10-20 (!) and am serving only about 10%.
Any suggestions on things to try? Is this slowdown between 1.3 and
2.0 a known (or familiar) problem? Haven't tried FastCGI yet. I
really want to understand what has happened, and why, before I inject
more changes into the environment.
Old: New:
Apache 1.3 2.0.50
Mapserver 4.4.0 4.6.1
PHP 4.3.8 4.4.0
Am now using PHP-bundled GD.
mapserv -v
MapServer version 4.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE INPUT=EPPL7 INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
TIA,
Hal
