Scale Bar Object and True type fonts
Richard Orth - osmoGIS Incorporated rco at OSMOGIS.COM
Wed Oct 26 11:33:31 EDT 2005
Maybe you have done this since posting. Have you reviewed the mapfile
documentation regarding the scalebar? In that section you will find a
reference to the label object. Tracking down the label object shows
three items you will need to include; a fontset file, a font parameter,
and a type parameter
Richard C Orth
Aniruddha S. Khadkikar wrote:
> Is it possible to use truetype fonts for labels in the scale bar object.
> Bitmap parameters are being rendered successfully, but scalebar fails
> to draw when I define MS_TRUETYPE and try to use arial font. There are
> no problems with the fontset definitions as location labels are being
> rendered successfully.
> Or is this issue still not addressed?
> Thanks in advance,
> Aniruddha
