FW: [UMN_MAPSERVER-USERS] Upgrade Problems - Additional Info
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Wed Oct 26 14:46:50 EDT 2005
Assefa,
http://dl.maptools.org/dl/mapserver-4.6.1-win32-php5.0.5.zip still has
an older gdal in there. Can we get an updated distro with GDAL 1.3 and
PHP 5.0.5 / MapServer 4.6.1?
..Tom
> -----Original Message-----
> From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> Sent: Wednesday, 26 October, 2005 14:31
> To: Kralidis,Tom [Burlington]
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] FW: [UMN_MAPSERVER-USERS]
> Tom,
> I have upgraded the php/mapscript download site with new windows
> binaries (http://www.maptools.org/php_mapscript/).
> Later,
> Kralidis,Tom [Burlington] wrote:
> > Everyone,
> > Follow up to this thread.
> > It seemed that an updated gdal fixed this issue. The gdal
> used with
> > the distro Tim was using was 1.2.6.
> > Having said this, where can one fetch a Win32 dist of
> MapServer 4.6.1
> > / PHP 5.0.5 / GDAL 1.3.1 ? I'm guessing this will be a hot
> item (alot
> > of my stakeholders share Tim's type of configuration and connection
> > bindings).
> > Thanks for Frank and Tim for their guidance and testing support.
> > Cheers
> > ..Tom
> > From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> > On Behalf Of Kralidis,Tom [Burlington]
> > Sent: Monday, 17 October, 2005 12:29
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: Re: [UMN_MAPSERVER-USERS] Upgrade Problems -
> Additional Info
> >>On 10/17/05, Kralidis,Tom [Burlington]
> <Tom.Kralidis at ec.gc.ca> wrote:
> >>>Is or has something happened to the way the .ovf or underlying OGR
> >>>process handles precision of coordinates when doing
> spatial filters?
> >>Tom,
> >>I haven't dug through the previous emails closely to see
> what is going
> >>on, but I thought I should answer this.
> >>There has been a substantial improvement in the amount of precision
> >>OGR maintains for WKT and GML encodings of geometries. The changes
> >>were applied a couple months ago.
> >>They are definately in GDAL/OGR 1.3.1 and might be in 1.3.0.
> >>OGR spatial filtering will also now use GEOS if built-in. It is
> >>possible that some "on the edge" situations would give different
> >>results now compared to in the past.
> >>I'm not sure if any of this relates to the problem you are seeing
> >>though.
> > Thanks for the info. I don't think these instances are
> using WKT/GML
> > as input or output, if that's what you mean. Basic .ovf
> connection to
> > provide WMS output. Is there anything we can do on our end to help
> > with this issue? The problem is basically:
> > ENVIRONMENT
> > OS: Win32
> > MapServer: 4.6.1 windows dist (non ms4w package from
> > http://maptools.org/dl)
> > Layer Data connection: OGR .ovf connection to M$ SQL Server 2000
> > SCENARIO 1
> > - invoke OGC:WMS GetMap request against said layer with coordinates
> > formatted with 8 decimals
> http://cabin.cciw.ca/cabin_ows.asp?version=1.1.1&service=WMS&request=G
> > et
> Map&layers=CABINPoints&styles=&bbox=-141.00000000,35.18749999,
> -51.999999
> > 99,90.81250000&format=image/png&srs=EPSG:4326&width=500&height=300
> > Result: works
> > SCENARIO 2
> > formatted with 9 decimals
> > et
> Map&layers=CABINPoints&styles=&bbox=-141.000000002,35.18749999
> 8,-51.9999
> 99997,90.812500001&format=image/png&srs=EPSG:4326&width=500&height=300
> > Result: watch server timeout ensue
> > NOTES
> > - this does not exist when the layer data connection is a
> shapefile,
> > for example
> > ..Tom
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
