date drop down menu
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Oct 26 17:41:30 EDT 2005
The answer depends on what API to mapserver you are using. If you are
using CGI then it might be a simple as defining a form on your page the
is submitted to mapserver where the drop name is YEAR and is assigned a
value that is the view name and then in your mapfile use %YEAR% as a
variable substitution in the DATA "... %YEAR% ..." statement.
-Steve Woodbridge
Danna Dowdy wrote:
> I am working on a basic mapping application that currently displays data
> from a spatial database based on variable groupings. I have individual
> views set up for each individual layer and have the grouping set up in
> the legend template. I would like to add a drop down menu somewhere on
> the interface so that the user could select a year and plot whatever
> layers are chosen for that particular year. Could someone point me in
> the right direction of how to do this?
