filter
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Oct 26 21:38:33 EDT 2005
Kevin,
You should be able to do it without the filteritem. You should try
something like FILTER ('[DXF_LAYER]' ne 'BACKGROUND')
Later,
Kevin Flanders wrote:
> Do I need to set FILTERITEM or can I put the entire expression inside of
> FILTER?
> I need to filter a shapefile so that all features where [DXF_LAYER] <>
> 'BACKGROUND' show on my map.
> So, I have tried:
> FILTER "[DXF_LAYER] <> 'BACKGROUND' "
> this did not work....
> How do I setup FILTER parameters for this?
> Kevin
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
