Dynamic Layer Creation Problem
Sean Gillies
sgillies at FRII.COM
Sat Oct 29 21:02:31 EDT 2005
On Oct 29, 2005, at 6:54 PM, Stephen Woodbridge wrote:
> Hi all,
> I know this has been covered before but I haven't been able to find
> anything that helps. I'm doing perl mapscript.
> if ($line->{numpoints}) {
> warn "numpoints=$line->{numpoints}\n"; # reports 257
> my $lay = new mapscript::layerObj($map);
> $lay->{status} = 1;
> $lay->{type} = $mapscript::MS_LAYER_LINE;
> $lay->{name} = "tsp_route";
> my $class = new mapscript::classObj($lay);
> #$class->{status} = 1; # doesn't help
> my $style = new mapscript::styleObj($class);
> # what should the value for pen be? tried 0 and 1 to no luck
> $style->{color} = new mapscript::colorObj(255,0,0,1);
> #$style->{size} = 1; # doesn't help
> #$style->{symbol} = 1; # doesn't help
> warn "numclasses=$lay->{numclasses}\n"; # reports 1
> warn "numstyles=$class->{numstyles}\n"; # reports 1
> my $shp = new mapscript::shapeObj($mapscript::MS_SHAPE_LINE);
> $shp->add($line);
> $shp->draw($map, $lay, $img);
> This code is running but is not drawing the polyline, $line->
> {numpoints}
> = 257 points.
> Yes, I know I can template this in the mapfile, but I would rather
> not.
> We have all these function in mapscript and it seems they should just
> work if you do the logical thing like above.
> -Steve W.
Steve,
You're neglecting to set the classindex attribute of your "shp"
shapeObj. There are other problems in your code as well, but that's
most likely the main one.
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
