Using WMS time dimension with rasters?
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Mon Oct 31 17:08:28 EST 2005
Jeroen Ticheler wrote:
> Hi!
> Happy to see this discussion and implementation progressing! This
> (seeing more clients & servers with time support in WMS) is indeed
> very true. We are working to get temporal data online both as WMS and
> WCS. Having a good support for that in MapServer would be a real asset,
> and actually allow us to use MapServer also for these data sets.
> In fact, this also gets to the problem I faced so far while
> implementing this; One common Map file will not do to have both a WMS
> and WCS with time support running, they are slightly different in the
> way they have to be configured (the WCS needs special layer that gives
> an error when accessing the service as WMS, at least that is what I ran
> into when following the different WMS and WCS time examples).
> Are there plans to align the two services?
The short answer is yes :) There is a bug opened on it (Bug 1506). Note
that it will be adressed only after the 4.8 release.
Later,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
