PHP on IIS method to 'hide' map= in OGC requests?
Pagurek,Debbie [NCR]
Debbie.Pagurek at EC.GC.CA
Fri Sep 2 10:11:24 EDT 2005
This page has an example of how to put a wrapper around mapserver in
order to "hide" the map= part of OGC requests. I am using PHP on a
windows server using IIS, and I was wondering if anyone out there has a
similar method to do this, but using PHP?
http://mapserver.gis.umn.edu/doc46/wms-server-howto.html
Thanks,
D. Pagurek
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Daniel Morissette
Sent: Friday, September 02, 2005 9:43 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] MapServer 4.6.1 released
MapServer 4.6.1 has been released. This new release addresses a few
issues that were found since version 4.6.0 and contains no new
functionality. The list of fixes is included at the end of this message.
The source package is available in the MapServer downloads page:
http://mapserver.gis.umn.edu/dload.html
and Windows binaries should be available shortly at the usual locations,
see:
http://mapserver.gis.umn.edu/win32binaries.html
Regards,
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Version 4.6.1 (2005-08-26)
- Typemaps for C# to enable the imageObj.getBytes() method (bug 1389).
- bug 1307: Enable -DUSE_ZLIB via configure for compressed SVG output.
- bug 1372: mapresample.c - ensure that multi-band raw results can be
resampled.
- bug 1418: Fixed sortshp.c to free shapes after processing to avoid
major
memory leak.
- bug 1402: fixed mappool.c so that any thread can release a connection,
not just it's allocator.
- Bug 1408: Fixed missing space in GML MultiLineString output
- Bug 1399: Fixed copy of processing directives within a layer copy.
- Bug 1312: Problems with string initialization when building tmp
files. It was cuasing a problem for wms client layers.
- Bug 1390: Fix svg output for multipolygons.
- Bug 1141: Fixed problem with GetLegendGraphic on layers with
status=off
