Multiple point symbols
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Fri Sep 2 14:03:45 EDT 2005
We made groupd of trees as an image then applied the image as a symbol
to a polygon fill. You could do the same for points and by the number of
points in the image you could get a density. But I'm not sure if this is
what you need.
What data type to you want to use to display this with and what do you
want the display to look like?
-Steve W.
Bob Basques wrote:
> All,
> More symbol stuff.
> Is there a way to make a symbol that is basically a group of points?
> Along the lines of a grid fill pattern, only at the Symbol level?
> bobb
