Multiple point symbols
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Fri Sep 2 14:47:20 EDT 2005
OK, so why not make them images.
The problem I see in general with this plan is that as you zoom in on
them the number of pixels between your regularly spaced points
increases. So you will always be dealing with issues of scaling things
and I don't think you will get it to look right.
Can you convert your grid points into polygons and do a polygon fill?
-Steve
Bob Basques wrote:
> this is going to sound wierd, but I want make a grid pattern of of
> regularly space grid points.
> I have points at equal distances that I want to make appear that they
> are a girdded filled poly area.
> Does that make any sense?   something like a checkerboard pattern but at
> a pixel level to imitate a transparency.
> I was just trying to pur two points into a symbol like so:
> |            |      O     |
> |      O     |            |
> Just two points, The symbol would be 2 pixels by two pixels, or some
> mutiple of this.  Then if I place two of these point side by side they
> would look like a filled patern (a polygon fill) but still be plotted as
> points.
> points 0 0 END
> points 1 1 END
> But this doesn't work for a POINT Symbol.  It break when there are two
> POINT vaules for a POINT symbol type.
> bobb
> Stephen Woodbridge wrote:
>> We made groupd of trees as an image then applied the image as a symbol
>> to a polygon fill. You could do the same for points and by the number
>> of points in the image you could get a density. But I'm not sure if
>> this is what you need.
>> What data type to you want to use to display this with and what do you
>> want the display to look like?
>> -Steve W.
>> Bob Basques wrote:
>>> All,
>>> More symbol stuff.
>>> Is there a way to make a symbol that is basically a group of points?
>>> Along the lines of a grid fill pattern, only at the Symbol level?
>>> bobb
