Multiple point symbols
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Sep 2 15:46:06 EDT 2005
Then I would make the point symbol an image and be done with it. That
should work fine for mapserver.
-Steve
Bob Basques wrote:
> Stephen Woodbridge wrote:
>> OK, so why not make them images.
>> The problem I see in general with this plan is that as you zoom in on
>> them the number of pixels between your regularly spaced points
>> increases. So you will always be dealing with issues of scaling things
>> and I don't think you will get it to look right.
> Actually, they stay constant. they use pixel coordinates to display by.
> The symbols are always the same size no matter the zoom level. The
> gridding is applied to the image pixel coordinates, not the MapServer
> coordinate space.
> Can you convert your grid points into polygons and do a polygon fill?
> Would add a lot of complication and excess data to the process, I only
> need to track the center point right now for example. It really needs
> to be a symbol, as the grid of points is generated dynamically.
> bobb
