Mapserver 4.6.1 Make problems - mapogr.o
Steve Benzo steve_benzo at YAHOO.COM
Fri Sep 2 17:05:55 EDT 2005
Daniel,
> That's possible if you link with libs that are not
> in your default lib
> path settings.
I set the ldlibpath to the libs that mapserver
requires before i compile, but it doesn't seem to
'remember' those when it comes time to run mapserver
later? Is there a way to hard code those values at
compile time?
> Did you look in your Apache error_log to look for
> hints? It may be that
> your Apache config is also missing the
> ld_library_path settings, that
> would explain the problem, and you would see
> something to that effect in
> the error_log.
> Daniel
The error log shows the same errors I get when I try
to run mapserver without those libs defined:
[Fri Sep 02 16:53:03 2005] [error] [client xxx]
Premature end of script headers: mapserv_new
ld.so.1: /usr/local/apache/cgi-bin/mapserv_new: fatal:
libclntsh.so.9.0: open failed: No such file or
directory
PS Thanks a lot for your help on this!
____________________________________________________
Start your day with Yahoo! - make it your home page
http://www.yahoo.com/r/hs
