WMS - Reprojecting and losing transparency?
Peter Giencke
pgiencke at GLC.ORG
Tue Sep 6 19:43:31 EDT 2005
Am I right to assume that under in the following circumstance, a
'reprojected' wms layer will lose its transparency? I did some digging and
couldn't find a straight answer...
Below is a parred down version of the mapfile I'm using; it becomes
untransparent after the projection to UTM. Hopefully I'm wrong and there's a
way to do this....
-pete
MAP
IMAGETYPE PNG24 #IMAGETYPE DOESN'T SEEM TO MATTER HERE
EXTENT 1074253.10 4816300.87 1617397.14 5238582.46
UNITS meters
PROJECTION ##########UTM 17N
"init=epsg:26916"
END
END
LAYER
NAME jpl3
METADATA
"wms_title" "jpl2"
"wms_srs" "EPSG:4326"
END
TYPE RASTER
TRANSPARENCY 40
STATUS default
CONNECTIONTYPE WMS
CONNECTION
"http://wms.jpl.nasa.gov/wms.cgi?SERVICENAME=OGC:WMS&VERSION=1.1.1&REQUEST=G
etMap&layers=global_mosaic&styles=&srs=EPSG:4326&format=image/png"
PROJECTION
"init=epsg:4326" ##########GEOGRAPHIC
END
END
END
