Polygon Buffer Query
Lowell Filak
lfilak at MEDINACO.ORG
Wed Sep 7 09:14:32 EDT 2005
The following message was sent by Abe Gillespie
<abe.gillespie at GMAIL.COM> on Sun, 4 Sep 2005 16:31:59 -0400.
> Is there a way to do this? queryByPoint has the ability to supply a
> radius but queryByShape does. I thought that setting the layer's
> TOLERANCE and TOLERANCEUNITS would help, but it doesn't seem to. If
> this isn't built in functionality, could anyone point me to an
> algorithm that I can use to manually buffer a polygon before I supply
> it to queryByShape?
Abe,
You will need to compile mapserver with GEOS support and use the
'$shape->buffer()' on the existing shape to buffer it and then use the
new shape ($bshape) to do the query.
One thing I noticed in using it - turn on the error reporting before
using shapeObj->buffer as there are a slew of things that can cause it
not to work:
my $geoserr = new mapscript::errorObj();
my $bshape = $shape->buffer($bdistance);
print "ERROR: $geoserr->{message}\n";
$bshape->setBounds();
HTH
Lowell
