EXPRESSION ([Bev_class]=1)
Richard Orth - osmoGIS Incorporated
rco at OSMOGIS.COM
Wed Sep 7 13:35:46 EDT 2005
Have you tried the EXPRESSION as a string? <>('[Bev_class]'='1')
Richard C Orth
Leopold Schefcik (MULTIMEDIAPLAN.AT) wrote:
>Hi, I'd like to show a layer (polygones) with the population density in 5
>clases
>(in different colors).
>I made the map file like in centrope_wms_bevdichte_2.map in the attachement
>is shown. e.g. with this:
> CLASS # Low Density
> MAXSCALE 120000
> MINSCALE 500
> EXPRESSION ([Bev_class]=1) #if it is a string ('[FIELD]'='value')
> SYMBOL 1
> COLOR 248 147 147
> SIZE 1
> END
> CLASS # High Density
> MAXSCALE 120000
> MINSCALE 500
> EXPRESSION ([Bev_class]=2)
> SYMBOL 1
> COLOR 249 36 36
> SIZE 1
> END
>But I only get this message (when I am using a relativ SHAPEPATH):
> msDrawMap():Failed to draw layer named `Bev_Density'.
>or no message and no layer with an absolute SHAPEPATH.
>Someone has an idea about this?
>Best regarts
>Leopold
>CapabilitiesRequest:
>http://213.47.127.15:8081/cgi-bin/mapserv.exe?MAP=/ms4w/apps/maplab-2.2/tuto
>rial/centrope_wms_bevdichte_2.map&SERVICE=wms&VERSION=1.1.1&REQUEST=GetCapab
>ilities
>-----Ursprüngliche Nachricht-----
>Von: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Im
>Auftrag von Michael Schulz
>Gesendet: Dienstag, 30. August 2005 13:40
>An: MAPSERVER-USERS at LISTS.UMN.EDU
>Betreff: Re: [UMN_MAPSERVER-USERS] 3 little Questions
>Hi Leopold,
>Q1: you will need to use a style that uses a vector symbol, e.g.
>SYMBOL
> NAME "circle"
> TYPE ellipse
> FILLED true
> POINTS
> 1 1
> END
>END
>then you can use the SIZE parameter in the mapfile on that symbol.
>Q2: Are you sre mapserver finds your shapefile in ./data? Did you try to
>use an absolute path to your data directory?
>Q3: Not sure, but did you try using a 24-bit output format, e.g. png24 ?
>Cheers, Michael
>Leopold Schefcik (MULTIMEDIAPLAN.AT) schrieb:
>>Hi list,
>>Question 1 (of 3):
>>maybe a simple question: How in general can I change the width of a
>>line(vectordata)?
>>Maybe not with 'SIZE' because regardless of which SIZE 1 or SIZE 50 or
>SIZE
>>100 there is allways a fine line.
>>CLASS
>> NAME "XC_Rivers"
>> STYLE
>> SYMBOL 0
>> COLOR 72 0 254
>> SIZE 100
>> MINSIZE 1
>> MAXSIZE 100
>> END
>> END
>>Question 2 (of 3):
>clases
>attachement
>>CLASS # Low Density
>> MAXSCALE 120000
>> MINSCALE 500
>> SYMBOL 1
>> COLOR 248 147 147
>> SIZE 1
>> END
>> MAXSCALE 120000
>> MINSCALE 500
>> SYMBOL 1
>> COLOR 249 36 36
>> SIZE 1
>> END
>>But I only get this message:
>>Question 3 (of 3):
>>I have a satellite tif for my background. It is in color. But in my client
>>it is only shown in black and white.
>>Do I have to change some command line here?
>>(map file for satellite picture is also in attachement:
>>centrope_wms_sat.map)
>>Thanks a lot for everybody, who is trying to help me here a little bit.
>>Best regards,
>>Leopold
>Michael Schulz mschulz at webgis.de
>in medias res Gesellschaft für Informationstechnologie mbH
>In den Weihermatten 66 Tel +49 (0)761 556959-5
>79108 Freiburg Fax +49 (0)761 556959-6
> www.webgis.de / www.zopecms.de
>NEU ++ UMN MapServer Hosting ++ http://www.webgis.de ++ NEU
