Mapunits in template
Berend Veldkamp
berend.veldkamp at ARIS.NL
Thu Sep 8 03:23:47 EDT 2005
listuser HH wrote:
> Berend Veldkamp wrote:
>> Hi,
>> I'm using mapserver as plain CGI and was wondering if there's a way to
>> use the "units" parameter of a map in the template file? I need this
>> to perform client side distance measurements.
>> Thanks, Berend
> Hi,
> I don't know if and how you can do that with a template. But what I
> would do is to use JavaScript. You should be able to make a small script
> where you calculate the measurement form the extent in map coordinates
> in reagard to the display coordinates. This only a quick thought but I
> think it should work.
> Best Regards,
> Norbert
Norbert,
I think I didn't make myself clear enough... I already have a
(JavaScript) function to measure distance in meters, feet, degrees, etc.
The problem is that I don't know in advance which units I should use. At
this moment I've hard-coded the correct units in my template file, but
I'd like the application to be general, so if I change the mapfile, or
the data, I shouldn't have to change anything else.
Berend
____________________________
Berend Veldkamp - ARIS
http://www.aris.nl/
