MySQL access and joins
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Thu Sep 8 19:21:33 EDT 2005
> -----Original Message-----
> From: Attila Csipa [mailto:plists at prometheus.org.yu]
> Sent: Thursday, 08 September, 2005 18:34
> To: Kralidis,Tom [Burlington]
> Cc: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] MySQL access and joins
> On Thursday 08 September 2005 21:02, Kralidis,Tom [Burlington] wrote:
> > > > Will simple MySQL tables work as the join table? I believe
> > > > --with-mygis will work on a non-sppatial DB
> > > Yes, but this will work ONLY for template based queries (this
> > Thanks for the info. What do you mean by template based
> queries? My
> > overall goal is to generate a map (with shp2img) whose
> mapfile defines
> > a layer which has a join btw a shapefile and MySQL table, and CLASS
> > items based on expressions in columns in the MySQL table.
> A query defines the 'what', not the 'how'. So basically you
> CAN do 'find me
> the shapefile points that have a mysql field value of X', but
> NOT DIRECTLY
> 'paint shapefile points with mysql field value X green' -
> which seems is what
> you want to do with it.
So this is to say that mapserv CGI can't handle this, but using
something like mapscript can? Is this what you mean by template
queries?
Thanks
..Tom
