DGN text rotation
Bart van den Eijnden BEN at SYNCERA-ITSOLUTIONS.NL
Fri Sep 9 05:14:07 EDT 2005
Thanks for reporting this back Sylvain.
It fixed my problem as well for TAB files.
It seems to be documented here:
http://mapserver.gis.umn.edu/doc46/ogr-howto.html
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Sylvain Beorchia <sbeorchia at GI-LEMANS.COM> 09/09/05 9:35 AM >>>
Hi list,
We found the solution. You just need to add an entry  "default   arial.ttf"
in the font.txt file and copy the arial.ttf file in the font directory of
your application...and it works...great!!
Sylvain Beorchia.
----- Original Message -----
From: "Sylvain Beorchia" <sbeorchia at GI-LEMANS.COM>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, September 08, 2005 11:05 AM
Subject: [UMN_MAPSERVER-USERS] DGN text rotation
hi list,
i am using mapserver and ogr (dgnlig) to display microstation dgn file.
display of dgn file is ok except the text rotation. all text have a 0°
rotation.
here is a piece of my map file :
LAYER
NAME dgn
TYPE ANNOTATION
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "test.dgn"
STYLEITEM "AUTO"
CLASS
END
END
i've used ogrinfo to check that dgnlib give the correct angle, it 's ok
is it possible to display dgn text with the correct rotation ?
if then can u give me a map file example ?
as u can see in the layer definition , i use "STYLEITEM AUTO", could it be
the problem ?
Thanls
